ArcGIS.Core.Geometry Namespace / GeometryEngine Class / DropMs Method / DropMs(Geometry,Boolean) Method
The input geometry.
If true, then a new geometry is returned with the Geometry.HasM property set to true no matter if the input geometry has the property set to true or not. If false and the geometry Geometry.HasM property is false, then an exception will be thrown.
    Sets all the M-values to NaN.
    Syntax
    Public Overloads Function DropMs( _
       ByVal geometry As Geometry, _
       ByVal allowNonMGeometry As Boolean _
    ) As Geometry
    Parameters
    geometry
    The input geometry.
    allowNonMGeometry
    Return Value
    The geometry with the M-values set to NaN. If the geometry is empty and the Geometry.HasM property is true, then the input geometry is returned unchanged. Otherwise, if allowNonMGeometry is true, a new geometry is returned with the Geometry.HasM property set to true.
    Exceptions
    ExceptionDescription
    Geometry is null.
    This geometry is not M-Aware and allowNonMGeometry is false.
    The method is not implemeted for GeometryBag.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
