ArcGIS.Desktop.Core Namespace / GeneralOptions Class / PortalProjectCustomDefaultGeodatabase Property
Example
    Gets and sets the default location for output files created in the local copy that are saved to a geodatabase.
    Syntax
    Public Property PortalProjectCustomDefaultGeodatabase As String
    public string PortalProjectCustomDefaultGeodatabase {get; set;}
    Example
    Get/Set Portal Project Options
      // access the current options
      var def_home = ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder;
      var def_gdb = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase;
      var def_tbx = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox;
      var deleteOnClose = ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose;
      var def_location = ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation;
      // set the options
      ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder = @"E:\data";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase = @"E:\data\usa.gdb";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox = @"E:\data\usa.tbx";
      ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose = false;
      ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation = @"E:\data";
    Requirements
    ArcGIS Pro version: 3.4 or higher.
