ArcGIS.Desktop.Core Namespace / GeneralOptions Class / PortalProjectDeleteLocalCopyOnClose Property
Example
    Gets and sets whether the downloaded local copy of a portal project is preserved when you close the project.
    Syntax
    Public Property PortalProjectDeleteLocalCopyOnClose As Boolean
    public bool PortalProjectDeleteLocalCopyOnClose {get; set;}
    Remarks
    The local copy (also called the cached copy) contains the changes you make to a portal project after downloading it. These changes are uploaded to the portal when you save the project.
    Example
    Get/Set Portal Project Options
      // access the current options
      var def_home = ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder;
      var def_gdb = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase;
      var def_tbx = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox;
      var deleteOnClose = ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose;
      var def_location = ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation;
      // set the options
      ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder = @"E:\data";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase = @"E:\data\usa.gdb";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox = @"E:\data\usa.tbx";
      ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose = false;
      ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation = @"E:\data";
    Requirements
    ArcGIS Pro version: 3.4 or higher.
