ArcGIS.Desktop.Core Namespace / GeneralOptions Class / PortalProjectDownloadLocation Property
Example
    Gets and sets the download location for portal projects
    Syntax
    Public Property PortalProjectDownloadLocation As String
    public string PortalProjectDownloadLocation {get; set;}
    Remarks
    Portal projects will be downloaded and cached in the location specified. Setting the download location to null or empty string will default it back to the original default (typically the Documents\ArcGIS\OnlineProjects in your user profile)
    Example
    Get/Set Portal Project Options
      // access the current options
      var def_home = ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder;
      var def_gdb = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase;
      var def_tbx = ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox;
      var deleteOnClose = ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose;
      var def_location = ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation;
      // set the options
      ApplicationOptions.GeneralOptions.PortalProjectCustomHomeFolder = @"E:\data";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultGeodatabase = @"E:\data\usa.gdb";
      ApplicationOptions.GeneralOptions.PortalProjectCustomDefaultToolbox = @"E:\data\usa.tbx";
      ApplicationOptions.GeneralOptions.PortalProjectDeleteLocalCopyOnClose = false;
      ApplicationOptions.GeneralOptions.PortalProjectDownloadLocation = @"E:\data";
    Requirements
    ArcGIS Pro version: 3.4 or higher.
