ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / Get3BandColor Method
    Get the three band composition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Get3BandColor() As ValueTuple(Of Integer,Integer,Integer)
    public ValueTuple<int,int,int> Get3BandColor()
    Return Value
    The red, green, blue band numbers.
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.4 or higher.
