ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetBackgroundColor Method
    Gets the raster background color. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetBackgroundColor() As CIMColor
    public CIMColor GetBackgroundColor()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    You can display the background of a raster dataset in a specific color or with transparency. This allows you to hide or highlight the background. Usually, the background color is set to transparent so that it is hidden.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
