ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetBackgroundValue Method
    Gets the RGB values used to indicate the background value. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetBackgroundValue() As ValueTuple(Of Double,Double,Double)
    public ValueTuple<double,double,double> GetBackgroundValue()
    Return Value
    The red, green, blue values of the background value.
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.4 or higher.
