ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetEnableCustomRenderingDefaults Method
    Gets the setting that allows you to set custom rendering defaults. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetEnableCustomRenderingDefaults() As Boolean
    public bool GetEnableCustomRenderingDefaults()
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.4 or higher.
