ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetMaximumUniqueValues Method
    Gets the maximum number of values to display. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetMaximumUniqueValues() As Integer
    public int GetMaximumUniqueValues()
    Exceptions
    ExceptionDescription
    Remarks
    The maximum number of values to display is set to 65,536 by default. This is the maximum number of values you can get with 16-bit data. Increasing this number allows you to work with datasets that have a greater bit depth without scaling them down to 16 bit; however, this increases computational effort and lowers performance.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
