ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetSkipFactorX Method
    Gets the X skip factor. That is the number of horizontal pixels between samples. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSkipFactorX() As Integer
    public int GetSkipFactorX()
    Return Value
    The X skip factor.
    Exceptions
    ExceptionDescription
    Remarks
    A skip factor controls the portion of the raster that is used when calculating the statistics. A value of 1 will use each pixel and a value of 2 will use every second pixel.
    The X skip factor can only range from 1 to the number of columns in the raster.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
