ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / GetUseFirstPerspectiveImageryLayer Method
    Gets if the application will work in the perspective view when an appropriate layers is added to a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetUseFirstPerspectiveImageryLayer() As Boolean
    public bool GetUseFirstPerspectiveImageryLayer()
    Exceptions
    ExceptionDescription
    Remarks
    This setting is used to specify if perspective imagery is displayed in image analysis mode, based on the image's coordinate system—columns and rows—rather than a map coordinate system.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
