ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / Set3BandColor Method
The red band number.
The green band number.
The blue band number
    Sets the three band composition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub Set3BandColor( _
       ByVal r As Integer, _
       ByVal g As Integer, _
       ByVal b As Integer _
    public void Set3BandColor(
       int r,
       int g,
       int b
    Parameters
    r
    g
    b
    Exceptions
    ExceptionDescription
    The red, green, blue bands must be a value between 1 and 3.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
