ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / SetGammaStretchValueRed Method
    Sets the gamma stretch red value. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetGammaStretchValueRed( _
       ByVal value As Double _
    public void SetGammaStretchValueRed(
       double value
    Parameters
    value
    Exceptions
    ExceptionDescription
    Value cannot be Nan.
    Remarks
    The value must be between 0.01 and 10. If a value is supplied outside this range then it is converted to be within the range.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
