Parameters
- maximum
- The maximum number of unique values to display.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
The value supplied must be greater than or equal to 0. If a negative value is supplied it will be set to 0.
