ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / SetSkipFactorY Method
    Sets the Y skip factor. That is the number of vertical pixels between samples. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetSkipFactorY( _
       ByVal skipfactorY As Integer _
    public void SetSkipFactorY(
       int skipfactorY
    Parameters
    skipfactorY
    Exceptions
    ExceptionDescription
    Remarks
    A skip factor controls the portion of the raster that is used when calculating the statistics. A value of 1 will use each pixel and a value of 2 will use every second pixel.
    The Y skip factor can only range from 1 to the number of rows in the raster.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
