ArcGIS.Desktop.Core Namespace / PyramidCompressionType Enumeration
Example Example
    Defines the compression type used when building raster pyramids. See RasterImageryOptions.GetPyramidCompressionMethod.
    Syntax
    Members
    MemberDescription
    Default Default. If the source data is compressed using a wavelet compression, it builds pyramids with the JPEG compression type; otherwise, LZ77 is used.
    JPEG JPEG.
    JPEG_YCbCr JPEG_YCbCr. A lossy compression using the luma (Y) and chroma (Cb and Cr) color space components.
    LZ77 LZ77.
    None No compression.
    Example
    Get/Set Raster and Imagery Options
    var ro = ApplicationOptions.RasterImageryOptions;
    await QueuedTask.Run(() =>
      var validCategories = ro.GetValidColorRampCategories();
      var validCategory = validCategories.FirstOrDefault();
      var colorRamps = ColorFactory.Instance.GetColorRampNames(validCategory);
      var newColorRampName = colorRamps.FirstOrDefault();
      var stretchedColorRamp = ro.GetStretchedColorRamp();
      var colorRampName = ro.GetStretchedColorRampName();
      ro.SetStretchedColorRampName(null);
      var classifyColorRamp = ro.GetClassifyColorRamp();
      colorRampName = ro.GetClassifyColorRampName();
      ro.SetClassifyColorRampName(newColorRampName);
      var discreteColorRamp = ro.GetDiscreteColorRamp();
      colorRampName = ro.GetDiscreteColorRampName();
      ro.SetDiscreteColorRampName(newColorRampName);
      var uniqueValueColorRamp = ro.GetUniqueValueColorRamp();
      colorRampName = ro.GetUniqueValueColorRampName();
      ro.SetUniqueValueColorRampName(newColorRampName);
      var customRendering = ro.GetEnableCustomRenderingDefaults();
      ro.SetEnableCustomRenderingDefaults(!customRendering);
      var sampleType = ro.GetResampleType();
      ro.SetResampleType(RasterResamplingType.CubicConvolution);
      var stretchType = ro.GetStretchType();
      ro.SetStretchType(RasterStretchType.PercentMinimumMaximum);
      var val = ro.GetNumberOfStandardDeviation();
      ro.SetNumberOfStandardDeviation(3);
      var (clipMin, clipMax) = ro.GetClipPercentage();
      ro.SetClipPercentage(12, 23);
      var red = ro.GetGammaStretchValueRed();
      var green = ro.GetGammaStretchValueGreen();
      var blue = ro.GetGammaStretchValueBlue();
      ro.SetGammaStretchValueRed(2);
      ro.SetGammaStretchValueGreen(20);
      ro.SetGammaStretchValueBlue(60);
      var displayBackground = ro.GetDisplayBackground();
      ro.SetDisplayBackground(!displayBackground);
      var (r, g, b) = ro.GetBackgroundValue();
      ro.SetBackgroundValue(4, 21, 61);
      var backColor = ro.GetBackgroundColor();
      ro.SetBackgroundColor(CIMColor.CreateRGBColor(255, 0, 0));
      var noData = ro.GetNoDataColor();
      ro.SetNoDataColor(CIMColor.CreateRGBColor(0, 255, 0));
      // cache
      var useCache = ro.GetUseImageServiceCache();
      ro.SetUseImageServiceCache(!useCache);
      //dataset
      var opt = ro.GetPyramidOption();
      ro.SetPyramidOption(ArcGIS.Desktop.Core.BuildPyramidOption.NeverBuild);
      var sample = ro.GetPyramidResampleMethod();
      ro.SetPyramidResampleMethod(PyramidResamplingMode.Bilinear);
      var compression = ro.GetPyramidCompressionMethod();
      ro.SetPyramidCompressionMethod(PyramidCompressionType.JPEG_YCbCr);
      var quality = ro.GetPyramidCompressionQuality();
      ro.SetPyramidCompressionQuality(32);
      var stats = ro.GetStatisticsOption();
      ro.SetStatisticsOption(CalculateStatisticOption.AlwaysCalculate);
      var x = ro.GetSkipFactorX();
      ro.SetSkipFactorX(3);
      var y = ro.GetSkipFactorY();
      ro.SetSkipFactorY(23);
      var useWorldFile = ro.GetUseWorldFile();
      ro.SetUseWorldFile(!useWorldFile);
      var createTiledTiff = ro.GetCreateTiledTiff();
      ro.SetCreateTiledTiff(!createTiledTiff);
      var maxUniqueValues = ro.GetMaximumUniqueValues();
      ro.SetMaximumUniqueValues(123456);
      var path = ro.GetProxyFileLocation();
      ro.SetProxyFileLocation("c:\\temp");
      var isExpanded = ro.GetIsMosaicLayerExpanded();
      ro.SetIsMosaicLayerExpanded(!isExpanded);
      var isVisible = ro.GetIsMosaicBoundaryVisible();
      ro.SetIsMosaicBoundaryVisible(!isVisible);
      isVisible = ro.GetIsMosaicFootprintVisible();
      ro.SetIsMosaicFootprintVisible(!isVisible);
      isVisible = ro.GetIsMosaicSeamlinesVisible();
      ro.SetIsMosaicSeamlinesVisible(!isVisible);
      isVisible = ro.GetIsMosaicPreviewVisible();
      ro.SetIsMosaicPreviewVisible(!isVisible);
      var (red_3band, green_3band, blue_3band) = ro.Get3BandColor();
      ro.Set3BandColor(2, 2, 2);
      var (ms_red, ms_green, ms_blue) = ro.GetMSColor();
      ro.SetMSColor(23, 24, 25);
      var enableCustomColorSchemes = ro.GetEnableCustomColorSchemes();
      ro.SetEnableCustomColorSchemes(!enableCustomColorSchemes);
      var useWavelengthInfo = ro.GetUseWavelengthInformation();
      ro.SetUseWavelengthInformation(!useWavelengthInfo);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Core.PyramidCompressionType
    Requirements
    ArcGIS Pro version: 3.4 or higher.
