ArcGIS.Desktop.Framework.Contracts Namespace / CustomControl Class / ClosePopup Method
    ClosePopup Method (CustomControl)
    Close the Popup if hosted in a drop down button.
    Syntax
    Protected Sub ClosePopup()
    protected void ClosePopup()
    Remarks
    It is sometimes necessary to manually close the Popup; for example, when 'staysOpenOnClick' is set to true and a button on the control needs to finally close the Popup.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
