ArcGIS.Core.Data Namespace / InsertCursor Class / Insert Method
A RowBuffer with the field values to be set for the new row.
Example
    Insert Method (InsertCursor)
    Inserts a new Row into the Table with a system-assigned object ID. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public long Insert(
       RowBuffer rowBuffer
    Public Function Insert( _
       ByVal rowBuffer As RowBuffer _
    ) As Long
    Parameters
    rowBuffer
    Return Value
    The object ID of the newly-inserted row.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Using an Insert Cursor
      // Insert Cursors are intended for use in CoreHost applications, not Pro Add-ins
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (Table citiesTable = geodatabase.OpenDataset<Table>("name\\of\\cities_table"))
          geodatabase.ApplyEdits(() =>
            using (InsertCursor insertCursor = citiesTable.CreateInsertCursor())
            using (RowBuffer rowBuffer = citiesTable.CreateRowBuffer())
              rowBuffer["State"] = "Colorado";
              rowBuffer["Name"] = "Fort Collins";
              rowBuffer["Population"] = 167830;
              insertCursor.Insert(rowBuffer);
              rowBuffer["Name"] = "Denver";
              rowBuffer["Population"] = 727211;
              // Insert more rows here
              // A more realistic example would be reading source data from a file
              insertCursor.Flush();
    Requirements
