ArcGIS.Core.Data Namespace / Table Class / CreateInsertCursor Method
Example
    Creates an InsertCursor instance in memory. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateInsertCursor() As InsertCursor
    public InsertCursor CreateInsertCursor()
    Return Value
    A InsertCursor used to quickly insert rows.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    When used in an ArcGIS Pro add-in, insert cursors should be used within an edit operation callback. For stand-alone CoreHost applications, calls to this method (and use of the insert cursor) should be enclosed within a call to Geodatabase.ApplyEdits.
    Example
    Using an Insert Cursor
      // Insert Cursors are intended for use in CoreHost applications, not Pro Add-ins
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (Table citiesTable = geodatabase.OpenDataset<Table>("name\\of\\cities_table"))
          geodatabase.ApplyEdits(() =>
            using (InsertCursor insertCursor = citiesTable.CreateInsertCursor())
            using (RowBuffer rowBuffer = citiesTable.CreateRowBuffer())
              rowBuffer["State"] = "Colorado";
              rowBuffer["Name"] = "Fort Collins";
              rowBuffer["Population"] = 167830;
              insertCursor.Insert(rowBuffer);
              rowBuffer["Name"] = "Denver";
              rowBuffer["Population"] = 727211;
              // Insert more rows here
              // A more realistic example would be reading source data from a file
              insertCursor.Flush();
    Requirements
