ArcGIS.Core.Data Namespace / VersionManager Class / GetVersionNames Method
Example
    Gets a IReadOnlyList of the names of all available Version in a given enterprise geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public IReadOnlyList<string> GetVersionNames()
    Public Function GetVersionNames() As IReadOnlyList(Of String)
    Return Value
    A IReadOnlyList of the names of all available Version in a given enterprise geodatabase.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Working with Versions
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (VersionManager versionManager = geodatabase.GetVersionManager())
          IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
          Version defaultVersion = versionManager.GetDefaultVersion();
          string testVersionName = versionNames.First(v => v.Contains("Test"));
          Version testVersion = versionManager.GetVersion(testVersionName);
          Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
          Geodatabase qaVersionGeodatabase = qaVersion.Connect();
          FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
          FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
    Requirements
