ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / InterpolateMsBetween Method
The multipart to copy and update.
The index of the part to start from.
The index of the point to start from. The point index is relative to the part.
The index of the part to end with.
The index of the point to end with. The point index is relative to the part.
Example
    InterpolateMsBetween Method (IGeometryEngine)
    Generates M-values by linear interpolation over a range of points.
    Syntax
    Function InterpolateMsBetween( _
       ByVal multipart As Multipart, _
       ByVal fromPart As Integer, _
       ByVal fromPoint As Integer, _
       ByVal toPart As Integer, _
       ByVal toPoint As Integer _
    ) As Multipart
    Parameters
    multipart
    fromPart
    fromPoint
    toPart
    toPoint
    Return Value
    An updated version of the input multipart.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    The input multipart is not M-Aware.
    M-values cannot be interpolated.
    Example
    Generates M-values by linear interpolation over a range of points - InterpolateMsBetween
      string json = "{\"hasM\":true,\"paths\":[[[0,0,-1],[1,0,0],[1,1,1],[1,2,2],[3,1,3],[5,3,4],[9,5,5],[7,6,6]]],\"spatialReference\":{\"wkid\":4326}}";
      polyline = PolylineBuilderEx.FromJson(json);
      // Interpolate between points 2 and 6
      Polyline outPolyline = GeometryEngine.Instance.InterpolateMsBetween(polyline, 0, 2, 0, 6) as Polyline;
      // The points of the output polyline are
      // (0, 0, -1), (1, 0, 0), (1, 1, 1), (1, 2, 1.3796279833912741), (3, 1, 2.2285019604153242), (5, 3, 3.3022520459518998), (9, 5, 5), (7, 6, 6)
    Requirements
