ArcGIS.Core.Geometry Namespace / GeometryEngine Class / DensifyByAngle Method
The multipart to be densified. If the input multipart is empty, then it is returned unchanged.
The maximum angle in radians that the output geometry can deviate from the input geometry. If the specified maximum angle is less than zero, then the default value of PI / 18 is used. If it is equal to zero, then the default value of 2 * xyResolution * 100 is used. The xyResolution is obtained from the spatial reference of the input geometry. If it is NaN, then the input geometry is returned unchanged.
    DensifyByAngle Method (GeometryEngine)
    Densifies the specified geometry.
    Syntax
    Public Function DensifyByAngle( _
       ByVal multipart As Multipart, _
       ByVal maxAngleDeviation As Double _
    ) As Geometry
    Parameters
    multipart
    maxAngleDeviation
    Return Value
    Returns the densified geometry. If the input geometry is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    Remarks
    The densify operation adds vertices to the input geometry.
    GeometryEngine DensifyByLength
    Requirements
