ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GetMsAtDistance Method
The multipart from which to get the M-values.
The distance along the multipart to retrieve the M-values.
Indicates whether the distance should be interpreted as length or ratio along the multipart.
The M-value at the specified distance.
The second M-value, if there is one. If the specified distance is not at the beginning or the ending of a part, then this value is NaN.
Example
    GetMsAtDistance Method (GeometryEngine)
    Get the M-values at the specified distance along the multipart. Two M-values can be returned if the specified distance is exactly at the beginning or the ending of a part.
    Syntax
    Public Sub GetMsAtDistance( _
       ByVal multipart As Multipart, _
       ByVal distance As Double, _
       ByVal asRatioOrLength As AsRatioOrLength, _
       ByRef mValue1 As Double, _
       ByRef mValue2 As Double _
    Parameters
    multipart
    distance
    asRatioOrLength
    mValue1
    mValue2
    Exceptions
    ExceptionDescription
    The input multipart is null.
    The input multipart is not M-Aware.
    Remarks
    If the input multipart is empty, then both mValue1 and mValue2 are NaN.
    Example
    Get the M values at the specified distance along the multipart
      string json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,-3],[-2000,-2000,-2]],[[-2000,-2000,1],[-2000,1000,2]]],\"spatialReference\":{\"wkid\":3857}}";
      polyline = PolylineBuilderEx.FromJson(json);
      // polyline has 2 parts
      GeometryEngine.Instance.GetMsAtDistance(polyline, 0, AsRatioOrLength.AsLength, out double m1, out double m2);
      // m1 = -3
      // m2 = NaN
      GeometryEngine.Instance.GetMsAtDistance(polyline, 500, AsRatioOrLength.AsLength, out m1, out m2);
      // m1 = -2.5
      // m2 = NaN
      GeometryEngine.Instance.GetMsAtDistance(polyline, 1000, AsRatioOrLength.AsLength, out m1, out m2);
      // m1 = -2
      // m2 = 1     // m2 has a value because distance 1000 is at the end of the first part, beginning of the second part
    Requirements
