ArcGIS.Core.Geometry Namespace / GeometryEngine Class / InsertMAtDistance Method
The multipart in which to set the M-value.
The M-value to set.
The distance along the multipart at which to set the M-value. If no point exists at the given distance, a new point is created with interpolated X and Y values.
Indicates whether the distance is interpreted as length or as a ratio along the multipart.
Indicates whether to create a new part at the split point (the point whose M-value is set) or not. MUST be false for polygons. For polylines, if true, the part on which the new split point falls is split into two parts with the newly added vertex serving as the end of the first part and the beginning of the second.
Indicates if a split happened at the split point. No split happens if createNewPart is false and the split point is at an existing vertex, or if createNewPart is true and a split part would be empty.
The index of the part that was modified. If createNewPart is true, partIndex refers to the added part and segmentIndex will be 0.
The index of the segment that was modified. The segment index is relative to the modified part.
Example
    InsertMAtDistance Method (GeometryEngine)
    Sets the M-value at the given distance along the multipart.
    Syntax
    Public Function InsertMAtDistance( _
       ByVal multipart As Multipart, _
       ByVal mValue As Double, _
       ByVal distance As Double, _
       ByVal asRatioOrLength As AsRatioOrLength, _
       ByVal createNewPart As Boolean, _
       ByRef splitHappened As Boolean, _
       ByRef partIndex As Integer, _
       ByRef segmentIndex As Integer _
    ) As Multipart
    Parameters
    multipart
    mValue
    The M-value to set.
    distance
    asRatioOrLength
    createNewPart
    splitHappened
    partIndex
    segmentIndex
    Return Value
    A multipart with the M-value set.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    createNewPart must be false for polygons.
    The input multipart is not M-Aware.
    Example
    Insert M value at the given distance - InsertMAtDistance
      string json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,-3],[-2000,-2000,-2],[-1000,-2000,null]]]}";
      polyline = PolylineBuilderEx.FromJson(json);
      // A point already exists at the given distance
      double m = -1;
      double distance = 2000;
      bool createNewPart = false;
      Polyline outputPolyline = GeometryEngine.Instance.InsertMAtDistance(polyline, m, distance, AsRatioOrLength.AsLength, createNewPart, out bool splitHappened, out int partIndex, out int segmentIndex) as Polyline;
      // splitHappened = false, partIndex = 0, segmentIndex = 2
      // outputPolyline.Points[2].M = -1
      json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,-3],[-2000,-2000,-2],[-1000,-2000,-1]],[[0,0,0],[0,1000,0],[0,2000,2]]],\"spatialReference\":{\"wkid\":3857}}";
      // A point already exists at the given distance, but createNewPart = true
      m = 1;
      distance = 3000;
      createNewPart = true;
      outputPolyline = GeometryEngine.Instance.InsertMAtDistance(polyline, m, distance, AsRatioOrLength.AsLength, createNewPart, out splitHappened, out partIndex, out segmentIndex) as Polyline;
      string outputJson = outputPolyline.ToJson();
      // splitHappened = true, partIndex = 2, segmentIndex = 0
      // outputJson = {"hasM":true,"paths":[[[-3000,-2000,-3],[-2000,-2000,-2],[-1000,-2000,-1]],[[0,0,0],[0,1000,1]],[[0,1000,1],[0,2000,2]]]}}
      // A new part has been created and the M values for outputPolyline.Points[4] and outputPolyline.Points[5] have been modified
      // A point does not exist at the given distance
      m = 1;
      distance = 3500;
      // splitHappened = true even though createNewPart = false because a new point was created
      // partIndex = 1, segmentIndex = 2
      // outputJson = {"hasM":true,"paths":[[[-3000,-2000,-3],[-2000,-2000,-2],[-1000,-2000,-1]],[[0,0,0],[0,1000,0],[0,1500,1],[0,2000,2]]]}
      // A new point has been inserted (0, 1500, 1) by interpolating the X and Y coordinates and M value set to the input M value.
    Requirements
