Public ReadOnly Property ProvenancePropertyInfo As ProvenancePropertyInfo
public ProvenancePropertyInfo ProvenancePropertyInfo {get;}
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
using (var kg = new KnowledgeGraph(kg_props))
// use the KnowledgeGraphPropertyInfo
var propInfo = kg.GetPropertyNameInfo();
var supportsProvenance = propInfo.SupportsProvenance;
var provenanceType = propInfo.ProvenanceTypeName;
var provenanceInfo = propInfo.ProvenancePropertyInfo;
//Instantiate an operation for the Create
var edit_op = new EditOperation()
Name = "Create a new provenance record",
SelectNewFeatures = true
//lets get the provenance table (provenance is not added to the
//map TOC)
var provenance_tbl = kg.OpenDataset<Table>("Provenance");
if (provenance_tbl == null)
return;
//we will add a row to the provenance for person entity
var person_tbl = kg.OpenDataset<Table>("Person");
//Arbitrarily retrieve the first "person" row
var instance_id = Guid.Empty;
using (var rc = person_tbl.Search())
if (!rc.MoveNext())
return;
instance_id = rc.Current.GetGlobalID();//Get the global id
//Define the provenance attributes - we need the names
//of the provenance properties from the KG ProvenancePropertyInfo
var kg_prop_info = kg.GetPropertyNameInfo();
var attribs = new Dictionary<string, object>();
var ppi = kg_prop_info.ProvenancePropertyInfo;
attribs[ppi.ProvenanceTypeNamePropertyName] =
person_tbl.GetDefinition().GetName();//entity type name
attribs[ppi.ProvenanceFieldNamePropertyName] = "name";//Must be a property/field on the entity
attribs[ppi.ProvenanceSourceNamePropertyName] = "Annual Review 2024";//can be anything - can be null
//note: Source type is controlled by the CodedValueDomain "esri__provenanceSourceType"
attribs[ppi.ProvenanceSourceTypePropertyName] = "Document";//one of ["Document", "String", "URL"].
attribs[ppi.ProvenanceSourcePropertyName] = "HR records";//can be anything, not null
attribs[ppi.ProvenanceCommentPropertyName] = "Rock star";//can be anything - can be null
//Add in the id of the provenance owner - our "person" in this case
attribs[ppi.ProvenanceInstanceIDPropertyName] = instance_id;
//Specify any additional custom attributes added to the provenance
//schema by the user as needed....
//attribs["custom_attrib"] = "Foo";
//attribs["custom_attrib2"] = "Bar";
//Create the provenance row
edit_op.Create(provenance_tbl, attribs);
if (edit_op.Execute())
//TODO: Operation succeeded
