ArcGIS.Desktop.Reports Namespace / Report Class / AddRelatedReport Method
The name of the relationship.
The user provided name of the related report section.
The report section name to insert relate report.
Object defining data source, fields, and definition query for the report.
An array CIMReportElementFieldProperties that includes the statatistics that will be used in the footer sections.
The path to the report template.
The name of the report styling.
    Adds a related report section to the report. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    relateName
    relateTitle
    insertSectionName
    reportDataSource
    statProperties
    templatePath
    styling
    Exceptions
    ExceptionDescription
    Requirements
