ArcGIS.Desktop.Mapping Namespace / ChartRendererDefinition Class / ChartFields Property
Example
    Gets or sets one or more fields be used to create the part of the charts. This is required.
    Syntax
    public List<string> ChartFields {get; set;}
    Public Property ChartFields As List(Of String)
    Example
    Pie chart renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using Pie chart symbols to represent data
    /// ![Pie chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/pie-chart.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      await QueuedTask.Run(() =>
        //Fields to use for the pie chart slices
        var chartFields = new List<string>
              "WHITE10",
               "BLACK10",
               "AMERIND10",
               "ASIAN10",
               "HISPPOP10",
               "HAMERIND10",
               "HWHITE10",
               "HASIAN10",
               "HPACIFIC10",
               "HBLACK10",
                "HOTHRACE10"
        PieChartRendererDefinition pieChartRendererDefn = new PieChartRendererDefinition()
          ChartFields = chartFields,
          ColorRamp = colorRamp,
          SizeOption = PieChartSizeOptions.Field,
          FieldName = "BLACK10",
          FixedSize = 36.89,
          DisplayIn3D = true,
          ShowOutline = true,
          Orientation = PieChartOrientation.CounterClockwise,
        //Creates a "Renderer"
        var pieChartRenderer = featureLayer.CreateRenderer(pieChartRendererDefn);
        //Sets the renderer to the feature layer
        featureLayer.SetRenderer(pieChartRenderer);
    Bar Chart Value renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using Bar chart symbols to represent data
    /// ![bar chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/bar-chart.png)
    /// </summary>
            "WHITE10",
              "BLACK10",
              "AMERIND10",
              "ASIAN10",
              "HISPPOP10",
              "HAMERIND10",
              "HWHITE10",
              "HASIAN10",
              "HPACIFIC10",
              "HBLACK10",
              "HOTHRACE10"
        BarChartRendererDefinition barChartRendererDefn = new BarChartRendererDefinition()
          BarWidth = 12,
          BarSpacing = 1,
          MaximumBarLength = 65,
          Orientation = ChartOrientation.Vertical,
          DisplayIn3D = true,
          ShowAxes = true,
        var barChartChartRenderer = featureLayer.CreateRenderer(barChartRendererDefn);
        featureLayer.SetRenderer(barChartChartRenderer);
    Stacked bar chart renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using stacked bar chart symbols to represent data
    /// ![stacked bar chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/stacked-bar-chart.png)
    /// </summary>
              "WHITE10",
               "BLACK10",
               "AMERIND10",
               "ASIAN10",
               "HISPPOP10",
               "HAMERIND10",
               "HWHITE10",
               "HASIAN10",
               "HPACIFIC10",
               "HBLACK10",
                "HOTHRACE10"
      StackedChartRendererDefinition barChartpieChartRendererDefn = new StackedChartRendererDefinition()
        SizeOption = StackChartSizeOptions.SumSelectedFields,
        Orientation = ChartOrientation.Horizontal,
        ShowOutline = true,
        DisplayIn3D = true,
        StackWidth = 8,
        StackLength = 25.87,
        var stackedBarChartChartRenderer = featureLayer.CreateRenderer(barChartpieChartRendererDefn);
        featureLayer.SetRenderer(stackedBarChartChartRenderer);
    Requirements
