ArcGIS.Desktop.Mapping Namespace / CompositeLayerWithTables Class / StandaloneTables Property
Example
    StandaloneTables Property (CompositeLayerWithTables)
    Gets a read-only collection of StandaloneTables from the composite layer with tables.
    Syntax
    Public ReadOnly Property StandaloneTables As ReadOnlyObservableCollection(Of StandaloneTable)
    public ReadOnlyObservableCollection<StandaloneTable> StandaloneTables {get;}
    Example
    Retrieve a table from its container
        var container = MapView.Active.Map;
        //the map standalone table collection
        var table = container.GetStandaloneTablesAsFlattenedList()
                                .FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
        //or from a group layer
        var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
        var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
        //or         grp_layer.GetStandaloneTablesAsFlattenedList().First()
        //or         grp_layer.StandaloneTables.Where(...).First(), etc.
        //show the table in a table view
        //use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
        FrameworkApplication.Panes.OpenTablePane(table2);
    Remove a Standalone table
        //get the first group layer that has at least one table
        var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
          .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
        //Note: Run within a QueuedTask
        //get the tables from the map container
        var tables = map.GetStandaloneTablesAsFlattenedList();
        //delete the first...
        if (tables.Count() > 0)
            map.RemoveStandaloneTable(tables.First());
            //or delete all of them
            map.RemoveStandaloneTables(tables);
        //delete a table from a group layer
        //assumes it has at least one table...
        grp_layer.RemoveStandaloneTable(grp_layer.StandaloneTables.First());
    Requirements
