ArcGIS.Core.Data.LinearReferencing Namespace / PointEventSourceOptions Class / PointEventSourceOptions Constructor / PointEventSourceOptions Constructor()
Example
    Initializes a new instance of the PointEventSourceOptions class. Use this constructor to omit the field for storing locating angles during the creation of a RouteEventSource using the dynamic segmentation process.
    Syntax
    Public Function New()
    public PointEventSourceOptions()
    Example
    Create a RouteEventSource via dynamic segmentation process for point events
      static void CreatePointEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string measureFieldName = "Measure")
        using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
        using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
          RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
          EventInfo eventInfo = new PointEventInfo(eventsTable, routeIdFieldName, measureFieldName);
          RouteEventSourceOptions routeEventSourceOptions = new PointEventSourceOptions(AngleType.Tangent)
          { ComplementAngle = true };
          using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
          using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
            // Locating errors
            IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
            // Route event source fields
            IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
            // Add RouteEventSource to the ArcGIS Pro map
            FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
              Name = "RoadAccidents"
            LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
