ArcGIS.Desktop.Mapping Namespace / GraphicsLayerCreationParams Class
Members Example
    Represents an object to initialize and create a graphics layer.
    Object Model
    GraphicsLayerCreationParams ClassLayer ClassLayer ClassLayer ClassLayer ClassLayer ClassCIMDataConnection ClassItem ClassCIMLayerDocument Class
    Syntax
    public class GraphicsLayerCreationParams : LayerCreationParams
    Public Class GraphicsLayerCreationParams
       Inherits LayerCreationParams
    Example
    Create GraphicsLayer
      if (map.MapType != MapType.Map)
        return;// not 2D
      var gl_param = new GraphicsLayerCreationParams { Name = "Graphics Layer" };
      await QueuedTask.Run(() =>
        //By default will be added to the top of the TOC
        graphicsLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, map);
        //Add to the bottom of the TOC
        gl_param.MapMemberIndex = -1; //bottom
        //Add a graphics layer to a group layer...
        var group_layer = map.GetLayersAsFlattenedList().OfType<GroupLayer>().First();
        LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, group_layer);
        //TODO...use the graphics layer
        // or use the specific CreateGroupLayer method
        LayerFactory.Instance.CreateGroupLayer(map, -1, "Graphics Layer");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.BaseCreationParams
          ArcGIS.Desktop.Mapping.MapMemberCreationParams
             ArcGIS.Desktop.Mapping.LayerCreationParams
                ArcGIS.Desktop.Mapping.GraphicsLayerCreationParams
    Requirements
