ArcGIS.Desktop.Mapping Namespace / MapMember Class / GetPath Method
    GetPath Method (MapMember)
    Gets the path of the dataset underneath the MapMember as a Uri. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPath() As Uri
    public Uri GetPath()
    Return Value
    The path of the dataset underneath the MapMember as a Uri. If the path does not exist, null is returned.
    Exceptions
    ExceptionDescription
    Requirements
