ArcGIS.Desktop.Mapping Namespace / NumberFormat Class / ValueToString Method
The format to use
The value to format
    Returns a formatted value based on the input ArcGIS.Core.CIM.CIMNumberFormat and value. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static string ValueToString(
       CIMNumberFormat numberFormat,
       double value
    Public Shared Function ValueToString( _
       ByVal numberFormat As CIMNumberFormat, _
       ByVal value As Double _
    ) As String
    Parameters
    numberFormat
    The format to use
    value
    The value to format
    Return Value
    A formatted value
    Exceptions
    ExceptionDescription
    Number format cannot be null
    Requirements
