ArcGIS.Desktop.Core Namespace / ExploratoryAnalysisOptions Class / CanSetElevationProfileOptions Method
The elevation profile options
Example
    Determines if the elevation profile options can be set.
    Syntax
    public bool CanSetElevationProfileOptions(
       ElevationProfileOptions elevationProfileOptions
    Public Function CanSetElevationProfileOptions( _
       ByVal elevationProfileOptions As ElevationProfileOptions _
    ) As Boolean
    Parameters
    Return Value
    True if the elevation profile options are valid. False otherwise.
    Remarks
    This function should be called prior to SetElevationProfileOptionsAsync to ensure the parameters are valid.
    Example
    Customize Elevation Profile Graph Display
      // customize the elevation profile graph options
      var options = new ElevationProfileOptions()
        LineColor = ColorFactory.Instance.CreateRGBColor(0, 0, 100),
        ShowAverageSlope = false,
        ShowMaximumSlope = false
      var eaOptions = ApplicationOptions.ExploratoryAnalysisOptions;
      if (eaOptions.CanSetElevationProfileOptions(options))
        await eaOptions.SetElevationProfileOptionsAsync(options);
      // or reset to default options
      var defaultOptions = eaOptions.GetDefaultElevationProfileOptions();
      if (eaOptions.CanSetElevationProfileOptions(defaultOptions))
        await eaOptions.SetElevationProfileOptionsAsync(defaultOptions);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
