ArcGIS.Desktop.Editing Namespace / KnowledgeGraphRelationshipDescription Class / KnowledgeGraphRelationshipDescription Constructor / KnowledgeGraphRelationshipDescription Constructor(RowHandle,RowHandle,IReadOnlyDictionary<String,Object>)
The RowHandle of the row in the origin table.
The RowHandle of the row in the destination table.
(Optional) The attributes to assign the new row in the relationship table.
Example
    Creates a new instance of the KnowledgeGraphRelationshipDescription class.
    Syntax
    Public Function New( _
       ByVal origin As RowHandle, _
       ByVal destination As RowHandle, _
       Optional ByVal attributes As IReadOnlyDictionary(Of String,Object) _
    public KnowledgeGraphRelationshipDescription(
       RowHandle origin,
       RowHandle destination,
       IReadOnlyDictionary<string,object> attributes
    Parameters
    origin
    destination
    attributes
    Example
    Create a new Relationship and New Entities 2
      var mv = MapView.Active;
      var createRel = await QueuedTask.Run(() =>
        //This example uses a KnowledgeGraphRelationshipDescription
        var edit_op = new EditOperation()
          Name = "Create entities and a relationship using a KG relate desc",
          SelectNewFeatures = true
        //We are just going to use mapmembers in this example
        //we could equally use feature classes/tables
        var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                      .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
        //From the KG Layer get the relevant child feature layer(s) and/or standalone
        //table(s)
        var org_fl = kg_layer.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                        .First(child_layer => child_layer.Name == "Organization");
        var person_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Person");
        var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "HasEmployee");
        var attribs = new Dictionary<string, object>();
        //New Organization
        attribs["Name"] = "Acme Ltd.";
        attribs["Description"] = "Specializes in household items";
        attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
        //Add it to the operation - we need the rowtoken
        var rowtoken_org = edit_op.Create(org_fl, attribs);
        attribs.Clear();//we are going to re-use the dictionary
        //New Person
        attribs["Name"] = "Bob";
        attribs["Age"] = "41";
        attribs["Skills"] = "Plumbing, Framing, Flooring";
        var rowtoken_person = edit_op.Create(person_stbl, attribs);
        attribs.Clear();
        //Create the new relationship using a KnowledgeGraphRelationshipDescription
        //Row handles act as the placeholders for the TO BE created new entities that will
        //be related
        var src_row_handle = new RowHandle(rowtoken_org);
        var dest_row_handle = new RowHandle(rowtoken_person);
        //Add any extra attribute information for the relation as needed
        attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
        var rel_desc = new KnowledgeGraphRelationshipDescription(
                                    src_row_handle, dest_row_handle, attribs);
        //Add the relate description to the edit operation
        edit_op.Create(rel_stbl, rel_desc);
        //Execute the create of the entities and relationship
        return edit_op.Execute();
    Requirements
    ArcGIS Pro version: 3.4 or higher.
