ArcGIS.Core.Data Namespace / SplitPolicy Enumeration
Example Example
    Controls the value of the attribute in the output features.
    Syntax
    Members
    MemberDescription
    DefaultValue The attributes of the resulting features take on the default value for the attribute of the given feature class or subtype.
    Duplicate The attributes of the resulting features take on a copy of the original object's attribute value.
    GeometryRatio The attributes of the resulting features are a ratio of the original feature's value.
    Example
    Creating a CodedValue domain
      // Must be called within QueuedTask.Run
      void CreateCodedDomainSnippet(Geodatabase geodatabase)
        // Create a CodedValueDomain description for water pipes
        CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription("WaterPipeTypes",
          FieldType.String, new SortedList<object, string> { { "C_1", "Copper" }, { "S_2", "Steel" } })
          SplitPolicy = SplitPolicy.Duplicate,
          MergePolicy = MergePolicy.DefaultValue
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Create a coded value domain
        CodedValueDomainToken codedValueDomainToken = schemaBuilder.Create(codedValueDomainDescription);
        schemaBuilder.Build();
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.SplitPolicy
    Requirements
