ArcGIS.Core.Data.Topology Namespace / ErrorType Enumeration
Example Example
    Specifies the type of topology error to be retrieved.
    Syntax
    Members
    MemberDescription
    ErrorAndException Both topology errors and exceptions.
    ErrorOnly Topology errors only.
    ExceptionOnlyTopology errors that have been marked as exception only.
    Example
    Mark and unmark errors or exceptions
      static void MarkAndUnmarkAsErrors(ArcGIS.Core.Data.Topology.Topology topology)
        // Get all the errors due to features violating the "PointProperlyInsideArea" topology rule.
        using (TopologyDefinition topologyDefinition = topology.GetDefinition())
          TopologyRule pointProperlyInsideAreaRule = topologyDefinition.GetRules().First(rule => rule.RuleType == TopologyRuleType.PointProperlyInsideArea);
          ErrorDescription errorDescription = new ErrorDescription(topology.GetExtent())
            TopologyRule = pointProperlyInsideAreaRule
          IReadOnlyList<TopologyError> errorsDueToViolatingPointProperlyInsideAreaRule = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsDueToViolatingPointProperlyInsideAreaRule.Count} feature violating the 'PointProperlyInsideArea' topology rule.");
          // Mark all errors from features violating the 'PointProperlyInsideArea' topology rule as exceptions.
          foreach (TopologyError error in errorsDueToViolatingPointProperlyInsideAreaRule)
            topology.MarkAsException(error);
          // Now verify all the errors from features violating the 'PointProperlyInsideArea' topology rule have indeed been
          // marked as exceptions.
          // By default, ErrorDescription is initialized to ErrorType.ErrorAndException.  Here we want ErrorType.ErrorOnly.
            ErrorType = ErrorType.ErrorOnly,
          IReadOnlyList<TopologyError> errorsAfterMarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterMarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the errors have been marked as exceptions.");
          // Finally, reset all the exceptions as errors by unmarking them as exceptions.
            topology.UnmarkAsException(error);
          IReadOnlyList<TopologyError> errorsAfterUnmarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterUnmarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the exceptions have been reset as errors.");
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.Topology.ErrorType
    Requirements
