ArcGIS.Core.Data.Topology Namespace / FeatureInfo Class / ObjectID Property
Example
    ObjectID Property (FeatureInfo)
    The object ID of the parent feature.
    Syntax
    Public ReadOnly Property ObjectID As Long
    public long ObjectID {get;}
    Example
    Explore topology graph
      static void ExploreTopologyGraph()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Build a topology graph using the extent of the topology dataset.
          topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
            using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
              IReadOnlyList<TopologyNode> topologyNodesViaCampsites12 = topologyGraph.GetNodes(campsites12);
              TopologyNode topologyNodeViaCampsites12 = topologyNodesViaCampsites12[0];
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12 = topologyNodeViaCampsites12.GetEdges();
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12CounterClockwise = topologyNodeViaCampsites12.GetEdges(false);
              foreach (TopologyEdge edgeConnectedToNodeViaCampsites12 in allEdgesConnectedToNodeViaCampsites12)
                TopologyNode fromNode = edgeConnectedToNodeViaCampsites12.GetFromNode();
                TopologyNode toNode = edgeConnectedToNodeViaCampsites12.GetToNode();
                bool fromNodeIsTheSameAsTopologyNodeViaCampsites12 = (fromNode == topologyNodeViaCampsites12);
                bool toNodeIsTheSameAsTopologyNodeViaCampsites12 = (toNode == topologyNodeViaCampsites12);
                IReadOnlyList<FeatureInfo> leftParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures();
                foreach (FeatureInfo featureInfo in leftParentFeaturesBoundedByEdge)
                  EnsureShapeIsNotEmpty(featureInfo);
                IReadOnlyList<FeatureInfo> leftParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures(false);
                foreach (FeatureInfo featureInfo in leftParentFeaturesNotBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures();
                foreach (FeatureInfo featureInfo in rightParentFeaturesBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures(false);
                foreach (FeatureInfo featureInfo in rightParentFeaturesNotBoundedByEdge)
        static void EnsureShapeIsNotEmpty(FeatureInfo featureInfo)
          using (Feature feature = featureInfo.GetFeature())
            // Process feature ...
    Find closest element from a topology graph
      static void FindClosestElement()
            MapPoint queryPointViaCampsites12 = null;
              queryPointViaCampsites12 = campsites12.GetShape() as MapPoint;
            double searchRadius = 1.0;
            TopologyElement topologyElementViaCampsites12 = topologyGraph.FindClosestElement<TopologyElement>(queryPointViaCampsites12, searchRadius);
            IReadOnlyList<FeatureInfo> parentFeatures = topologyElementViaCampsites12.GetParentFeatures();
            Console.WriteLine("The parent features that spawn 'topologyElementViaCampsites12' are:");
            foreach (FeatureInfo parentFeature in parentFeatures)
              Console.WriteLine($"\t{parentFeature.FeatureClassName}; OID: {parentFeature.ObjectID}");
            TopologyNode topologyNodeViaCampsites12 = topologyGraph.FindClosestElement<TopologyNode>(queryPointViaCampsites12, searchRadius);
            if (topologyNodeViaCampsites12 != null)
              // There exists a TopologyNode nearest to the query point within searchRadius units.
            TopologyEdge topologyEdgeViaCampsites12 = topologyGraph.FindClosestElement<TopologyEdge>(queryPointViaCampsites12, searchRadius);
            if (topologyEdgeViaCampsites12 != null)
              // There exists a TopologyEdge nearest to the query point within searchRadius units.
    Requirements
