ArcGIS.Core.Data.Topology Namespace / Topology Class
Members Example
    Topology Class
    Represents a topology dataset.
    Object Model
    Topology ClassDatastore ClassTopologyDefinition ClassEnvelope ClassValidationResult Class
    Syntax
    Public NotInheritable Class Topology
       Inherits ArcGIS.Core.Data.Dataset
       Implements System.IDisposable
    public sealed class Topology : ArcGIS.Core.Data.Dataset, System.IDisposable
    Example
    Open topology and process definition
      static void OpenTopologyAndProcessDefinition()
        // Open a geodatabase topology from a file geodatabase and process the topology definition.
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          ProcessDefinition(geodatabase, topology);
        // Open a feature service topology and process the topology definition.
        const string TOPOLOGY_LAYER_ID = "0";
        using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
        static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
          // Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
          // definition -- via the Topology dataset itself or via the Geodatabase.
          using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
            OutputDefinition(geodatabase, definitionViaTopology);
          using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
            OutputDefinition(geodatabase, definitionViaGeodatabase);
        static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
          Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
          Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
          IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
          Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
          foreach (string name in featureClassNames)
            // Open each feature class that participates in the topology.
            using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
            using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
              Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
    Requirements
