ArcGIS.Core.Data.Topology Namespace / TopologyEdge Class / Equals Method / Equals(Object) Method
The object to compare with the current object.
    Determines whether two TopologyEdge instances are equal.
    Syntax
    Public Overloads Overrides NotOverridable Function Equals( _
       ByVal obj As Object _
    ) As Boolean
    public override bool Equals(
       object obj
    Parameters
    obj
    Return Value
    true if the specified object is equal to the current object; otherwise, false.
    Remarks
    Semantically, if two managedTopologyEdge instances refer to the same backing nativeTopologyEdge instance in native code, they are considered equal.
    Requirements
