ArcGIS.Core.Data.Topology Namespace / TopologyEdge Class / Equality Operator
The object to compare with topologyEdge2.
The object to compare with topologyEdge1.
    Equality Operator (TopologyEdge)
    Determines whether two TopologyEdge instances are equal.
    Syntax
    Parameters
    topologyEdge1
    topologyEdge2
    Return Value
    true if topologyEdge1 is equal to topologyEdge2; otherwise, false.
    Remarks
    Semantically, if two managedTopologyEdge instances refer to the same backing nativeTopologyEdge instance in native code, they are considered equal.
    Requirements
