ArcGIS.Core.Data.Topology Namespace / ValidationDescription Class / ValidationDescription Constructor
The area of interest to validate the topology.
Example
    Initializes a new instance of the ValidationDescription class.
    Syntax
    Public Function New( _
       ByVal extent As Envelope _
    public ValidationDescription(
       Envelope extent
    Parameters
    extent
    Exceptions
    ExceptionDescription
    extent is null.
    Example
    Validate topology
      static void ValidateTopology()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // If the topology currently does not have dirty areas, calling Validate() returns an empty envelope.
          ValidationResult result = topology.Validate(new ValidationDescription(topology.GetExtent()));
          Console.WriteLine($"'AffectedArea' after validating a topology that has not been edited => {result.AffectedArea.ToJson()}");
          // Now create a feature that purposely violates the "PointProperlyInsideArea" topology rule.  This action will
          // create dirty areas.
          Feature newFeature = null;
          try
            // Fetch the feature in the Campsites feature class whose objectID is 2.  Then create a new geometry slightly
            // altered from this and use it to create a new feature.
            using (Feature featureViaCampsites2 = GetFeature(geodatabase, "Campsites", 2))
              Geometry currentGeometry = featureViaCampsites2.GetShape();
              Geometry newGeometry = GeometryEngine.Instance.Move(currentGeometry, (currentGeometry.Extent.XMax / 8), (currentGeometry.Extent.YMax / 8));
              using (FeatureClass campsitesFeatureClass = featureViaCampsites2.GetTable())
              using (FeatureClassDefinition definition = campsitesFeatureClass.GetDefinition())
              using (RowBuffer rowBuffer = campsitesFeatureClass.CreateRowBuffer())
                rowBuffer[definition.GetShapeField()] = newGeometry;
                geodatabase.ApplyEdits(() => { newFeature = campsitesFeatureClass.CreateRow(rowBuffer); });
            // After creating a new feature in the 'Campsites' participating feature class, the topology's state should be
            // "Unanalyzed" because it has not been validated.
            Console.WriteLine($"The topology state after an edit has been applied => {topology.GetState()}");
            // Now validate the topology.  The result envelope corresponds to the dirty areas.
            Console.WriteLine($"'AffectedArea' after validating a topology that has just been edited => {result.AffectedArea.ToJson()}");
            // After Validate(), the topology's state should be "AnalyzedWithErrors" because the topology currently has errors.
            Console.WriteLine($"The topology state after validate topology => {topology.GetState()}");
            // If there are no dirty areas, the result envelope should be empty.
            Console.WriteLine($"'AffectedArea' after validating a topology that has just been validated => {result.AffectedArea.ToJson()}");
          finally
            if (newFeature != null)
              geodatabase.ApplyEdits(() => { newFeature.Delete(); });
              newFeature.Dispose();
          // Validate again after deleting the newly-created feature.
    Requirements
