ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / ConstructPolygonsFromPolylines Method
The set of polylines to create polygons from. If a polyline has curves, a densified copy of it is used to construct the polygons.
Example
    ConstructPolygonsFromPolylines Method (IGeometryEngine)
    Generates polygons from a set of polylines.
    Syntax
    Function ConstructPolygonsFromPolylines( _
       ByVal polylines As IEnumerable(Of Polyline) _
    ) As IReadOnlyList(Of Polygon)
    IReadOnlyList<Polygon> ConstructPolygonsFromPolylines(
       IEnumerable<Polyline> polylines
    Parameters
    polylines
    Return Value
    Returns the polygons. If none are created, then the collection returned is empty.
    Exceptions
    ExceptionDescription
    The polylines is null.
    Remarks
    The polylines may cross rather than be connected from end to end.
    Example
    Construct a Polygon from a set of Polylines
        List<Coordinate2D> firstLinePts = [new Coordinate2D(1.0, 1.0), new Coordinate2D(1.0, 4.0)];
        List<Coordinate2D> secondLinePts = [new Coordinate2D(4.0, 4.0), new Coordinate2D(4.0, 1.0)];
        List<Coordinate2D> thirdLinePts = [new Coordinate2D(0.0, 2.0), new Coordinate2D(5.0, 2.0)];
        List<Coordinate2D> fourthLinePts = [new Coordinate2D(0.0, 3.0), new Coordinate2D(5.0, 3.0)];
        // build the polylines
        List<Polyline> polylines =
          PolylineBuilderEx.CreatePolyline(firstLinePts),
      PolylineBuilderEx.CreatePolyline(secondLinePts),
      PolylineBuilderEx.CreatePolyline(thirdLinePts),
      PolylineBuilderEx.CreatePolyline(fourthLinePts),
        // construct polygons from the polylines
        var polygons = GeometryEngine.Instance.ConstructPolygonsFromPolylines(polylines);
        // polygons.Count = 1
        // polygon coordinates are (1.0, 2.0), (1.0, 3.0), (4.0, 3.0), (4.0, 2.0)
    Requirements
