ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / Intersects(Envelope) Method
Envelope to test intersection against.
Example
    Checks if the input Envelope intersects the EnvelopeBuilderEx.
    Syntax
    public bool Intersects(
       Envelope envelope
    Public Function Intersects( _
       ByVal envelope As Envelope _
    ) As Boolean
    Parameters
    envelope
    Return Value
    True if the envelopes intersect. False if they do not.
    Exceptions
    ExceptionDescription
    The input envelope is null.
    Example
    Intersect two Envelopes
      // use the convenience builders
      Envelope env1 = EnvelopeBuilderEx.CreateEnvelope(0, 0, 1, 1, SpatialReferences.WGS84);
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(0.5, 0.5, 1.5, 1.5, SpatialReferences.WGS84);
      bool intersects = env1.Intersects(env2); // true
      Envelope env3 = env1.Intersection(env2);
      // or use the builderEx constructors which don't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(0, 0, 1, 1, SpatialReferences.WGS84);
      intersects = builderEx.Intersects(env2);
      builderEx.Intersection(env2);   // note this sets the builder to the intersection
      env3 = builderEx.ToGeometry() as Envelope;
    Requirements
