ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / ToGeometry Method
Example
    ToGeometry Method (EnvelopeBuilderEx)
    Returns an Envelope instance representing the current state of the builder.
    Syntax
    public new Envelope ToGeometry()
    Public Shadows Function ToGeometry() As Envelope
    Return Value
    Example
    Construct an Envelope
      // Use a builderEx convenience method or use a builderEx constructor.
      MapPoint minPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint maxPt = MapPointBuilderEx.CreateMapPoint(2.0, 2.0);
      Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(minPt, maxPt);
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(minPt, maxPt);
      envelope = builderEx.ToGeometry() as Envelope;
    Union two Envelopes
      // use the convenience builders
      Envelope env1 = EnvelopeBuilderEx.CreateEnvelope(0, 0, 1, 1, SpatialReferences.WGS84);
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(0.5, 0.5, 1.5, 1.5, SpatialReferences.WGS84);
      Envelope env3 = env1.Union(env2);
      double area = env3.Area;
      double depth = env3.Depth;
      double height = env3.Height;
      double width = env3.Width;
      double len = env3.Length;
      MapPoint centerPt = env3.Center;
      Coordinate2D coord = env3.CenterCoordinate;
      bool isEmpty = env3.IsEmpty;
      int pointCount = env3.PointCount;
      // coordinates
      //env3.XMin, env3.XMax, env3.YMin, env3.YMax
      //env3.ZMin, env3.ZMax, env3.MMin, env3.MMax
      bool isEqual = env1.IsEqual(env2);    // false
      // or use the builderEx constructors which don't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(0, 0, 1, 1, SpatialReferences.WGS84);
      builderEx.Union(env2);      // builder is updated to the result
      depth = builderEx.Depth;
      height = builderEx.Height;
      width = builderEx.Width;
      centerPt = builderEx.Center;
      coord = builderEx.CenterCoordinate;
      isEmpty = builderEx.IsEmpty;
      env3 = builderEx.ToGeometry() as Envelope;
    Intersect two Envelopes
      bool intersects = env1.Intersects(env2); // true
      Envelope env3 = env1.Intersection(env2);
      intersects = builderEx.Intersects(env2);
      builderEx.Intersection(env2);   // note this sets the builder to the intersection
    Expand an Envelope
      // convenience methods don't need to run on the MCT.
      Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(100.0, 100.0, 500.0, 500.0);
      // shrink the envelope by 50%
      Envelope result = envelope.Expand(0.5, 0.5, true);
      // builderEx constructors don't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(100.0, 100.0, 500.0, 500.0);
      builderEx.Expand(0.5, 0.5, true);
    Update Coordinates of an Envelope
      Coordinate2D minCoord = new Coordinate2D(1, 3);
      Coordinate2D maxCoord = new Coordinate2D(2, 4);
      Coordinate2D c1 = new Coordinate2D(0, 5);
      Coordinate2D c2 = new Coordinate2D(1, 3);
      // use the EnvelopeBuilderEx.  This constructor doesn't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(minCoord, maxCoord);
      // builderEx.XMin, YMin, Zmin, MMin  = 1, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 2, 4, 0, double.Nan
      // set XMin.  if XMin > XMax; both XMin and XMax change
      builderEx.XMin = 6;
      // builderEx.XMin, YMin, ZMin, MMin  = 6, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 6, 4, 0, double.Nan
      // set XMax
      builderEx.XMax = 8;
      // builderEx.XMax, YMax, ZMax, MMax = 8, 4, 0, double.Nan
      // set XMax.  if XMax < XMin, both XMin and XMax change
      builderEx.XMax = 3;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 0, double.Nan
      // set YMin
      builderEx.YMin = 2;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, 0, double.Nan
      // set ZMin.  if ZMin > ZMax, both ZMin and ZMax change
      builderEx.ZMin = 3;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, 3, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 3, double.Nan
      // set ZMax.  if ZMax < ZMin. both ZMin and ZMax change
      builderEx.ZMax = -1;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, -1, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, -1, double.Nan
      builderEx.SetZCoords(8, -5);
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, -5, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 8, double.Nan
      builderEx.SetXYCoords(c1, c2);
      // builderEx.XMin, YMin, ZMin, MMin  = 0, 3, -5, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 1, 5, 8, double.Nan
      builderEx.HasM = true;
      builderEx.SetMCoords(2, 5);
      var geomEx = builderEx.ToGeometry();
    Add an offset value to each of the M-values - OffsetMs
      // Create a polyline and add an offset of 2 to each of the M-values
      MapPointBuilderEx pointBuilder = new(0, 0)
        M = 1
      MapPoint point1 = pointBuilder.ToGeometry();
      pointBuilder.SetValues(2, 2);
      pointBuilder.M = 3;
      MapPoint point2 = pointBuilder.ToGeometry();
      polyline = PolylineBuilderEx.CreatePolyline([point1, point2], AttributeFlags.HasM);
      Polyline outPolyline = GeometryEngine.Instance.OffsetMs(polyline, 2) as Polyline;
      // The xy-values of the points in outPolyline are the same as the points in the input polyline.
      // The M-values in outPolyline are { 3, 5 }
      // Create an envelope and add an offset of 25 to each of the M-values
      EnvelopeBuilderEx envelopeBuilder = new(-5, 1, 2, 4)
        MMin = 10,
        MMax = 20
      Envelope envelope = envelopeBuilder.ToGeometry();
      Envelope outEnvelope = GeometryEngine.Instance.OffsetMs(envelope, 25) as Envelope;
      // The xy-values of the points in outEnvelope are the same as the points in the input envelope.
      // outEnvelope.MMin = 35, outEnvelope.MMax = 45
      // Add a negative offset to the M-values of the envelope
      outEnvelope = GeometryEngine.Instance.OffsetMs(envelope, -10) as Envelope;
      // outEnvelope.MMin = 0, outEnvelope.MMax = 10
    Requirements
