ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / IsEmpty Property
Example
    IsEmpty Property (EnvelopeBuilderEx)
    Gets a boolean indicating if the geometry of this builder is empty.
    Syntax
    public override bool IsEmpty {get;}
    Public Overrides NotOverridable ReadOnly Property IsEmpty As Boolean
    Example
    Union two Envelopes
      // use the convenience builders
      Envelope env1 = EnvelopeBuilderEx.CreateEnvelope(0, 0, 1, 1, SpatialReferences.WGS84);
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(0.5, 0.5, 1.5, 1.5, SpatialReferences.WGS84);
      Envelope env3 = env1.Union(env2);
      double area = env3.Area;
      double depth = env3.Depth;
      double height = env3.Height;
      double width = env3.Width;
      double len = env3.Length;
      MapPoint centerPt = env3.Center;
      Coordinate2D coord = env3.CenterCoordinate;
      bool isEmpty = env3.IsEmpty;
      int pointCount = env3.PointCount;
      // coordinates
      //env3.XMin, env3.XMax, env3.YMin, env3.YMax
      //env3.ZMin, env3.ZMax, env3.MMin, env3.MMax
      bool isEqual = env1.IsEqual(env2);    // false
      // or use the builderEx constructors which don't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(0, 0, 1, 1, SpatialReferences.WGS84);
      builderEx.Union(env2);      // builder is updated to the result
      depth = builderEx.Depth;
      height = builderEx.Height;
      width = builderEx.Width;
      centerPt = builderEx.Center;
      coord = builderEx.CenterCoordinate;
      isEmpty = builderEx.IsEmpty;
      env3 = builderEx.ToGeometry() as Envelope;
    Requirements
