ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / MMin Property
Example
    MMin Property (EnvelopeBuilderEx)
    Gets or sets the M minimum of this instance.
    Syntax
    public double MMin {get; set;}
    Public Property MMin As Double
    Remarks
    If the value passed in to set MMin is greater than MMax, then MMax will also be set to this value. To set both the minimum and maximum values simultaneously, use SetMCoords.
    Example
    Add an offset value to each of the M-values - OffsetMs
      // Create a polyline and add an offset of 2 to each of the M-values
      MapPointBuilderEx pointBuilder = new(0, 0)
        M = 1
      MapPoint point1 = pointBuilder.ToGeometry();
      pointBuilder.SetValues(2, 2);
      pointBuilder.M = 3;
      MapPoint point2 = pointBuilder.ToGeometry();
      polyline = PolylineBuilderEx.CreatePolyline([point1, point2], AttributeFlags.HasM);
      Polyline outPolyline = GeometryEngine.Instance.OffsetMs(polyline, 2) as Polyline;
      // The xy-values of the points in outPolyline are the same as the points in the input polyline.
      // The M-values in outPolyline are { 3, 5 }
      // Create an envelope and add an offset of 25 to each of the M-values
      EnvelopeBuilderEx envelopeBuilder = new(-5, 1, 2, 4)
        MMin = 10,
        MMax = 20
      Envelope envelope = envelopeBuilder.ToGeometry();
      Envelope outEnvelope = GeometryEngine.Instance.OffsetMs(envelope, 25) as Envelope;
      // The xy-values of the points in outEnvelope are the same as the points in the input envelope.
      // outEnvelope.MMin = 35, outEnvelope.MMax = 45
      // Add a negative offset to the M-values of the envelope
      outEnvelope = GeometryEngine.Instance.OffsetMs(envelope, -10) as Envelope;
      // outEnvelope.MMin = 0, outEnvelope.MMax = 10
    Requirements
