ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / YMin Property
Example
    YMin Property (EnvelopeBuilderEx)
    Gets or sets the Y minimum of this instance.
    Syntax
    public double YMin {get; set;}
    Public Property YMin As Double
    Remarks
    If the value passed in to set YMin is greater than YMax then YMax is also set to this value. To set both the minimum and maximum values simultaneously, use SetXYCoords.
    Example
    Update Coordinates of an Envelope
      Coordinate2D minCoord = new Coordinate2D(1, 3);
      Coordinate2D maxCoord = new Coordinate2D(2, 4);
      Coordinate2D c1 = new Coordinate2D(0, 5);
      Coordinate2D c2 = new Coordinate2D(1, 3);
      // use the EnvelopeBuilderEx.  This constructor doesn't need to run on the MCT.
      EnvelopeBuilderEx builderEx = new EnvelopeBuilderEx(minCoord, maxCoord);
      // builderEx.XMin, YMin, Zmin, MMin  = 1, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 2, 4, 0, double.Nan
      // set XMin.  if XMin > XMax; both XMin and XMax change
      builderEx.XMin = 6;
      // builderEx.XMin, YMin, ZMin, MMin  = 6, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 6, 4, 0, double.Nan
      // set XMax
      builderEx.XMax = 8;
      // builderEx.XMax, YMax, ZMax, MMax = 8, 4, 0, double.Nan
      // set XMax.  if XMax < XMin, both XMin and XMax change
      builderEx.XMax = 3;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 3, 0, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 0, double.Nan
      // set YMin
      builderEx.YMin = 2;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, 0, double.Nan
      // set ZMin.  if ZMin > ZMax, both ZMin and ZMax change
      builderEx.ZMin = 3;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, 3, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 3, double.Nan
      // set ZMax.  if ZMax < ZMin. both ZMin and ZMax change
      builderEx.ZMax = -1;
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, -1, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, -1, double.Nan
      builderEx.SetZCoords(8, -5);
      // builderEx.XMin, YMin, ZMin, MMin  = 3, 2, -5, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 3, 4, 8, double.Nan
      builderEx.SetXYCoords(c1, c2);
      // builderEx.XMin, YMin, ZMin, MMin  = 0, 3, -5, double.Nan
      // builderEx.XMax, YMax, ZMax, MMax = 1, 5, 8, double.Nan
      builderEx.HasM = true;
      builderEx.SetMCoords(2, 5);
      var geomEx = builderEx.ToGeometry();
    Requirements
