ArcGIS.Desktop.Core.UnitFormats Namespace / UnitFormatType Enumeration
Example Example
    Specifies the types of unit formatting
    Syntax
    Members
    MemberDescription
    Angular Angular
    Area Area
    Direction Direction
    Distance Distance
    Location Location
    Page Page
    Symbol2D Symbol 2D
    Symbol3D Symbol 3D
    Example
    Get The Full List of All Available Unit Formats
      //Note: Must be on the QueuedTask.Run()
      var unit_formats = Enum.GetValues(typeof(UnitFormatType))
                    .OfType<UnitFormatType>().ToList();
      System.Diagnostics.Debug.WriteLine("All available units\r\n");
      foreach (var unit_format in unit_formats)
        var units = DisplayUnitFormats.Instance.GetPredefinedProjectUnitFormats(unit_format);
        System.Diagnostics.Debug.WriteLine(unit_format.ToString());
        foreach (var display_unit_format in units)
          var line = $"{display_unit_format.DisplayName}, {display_unit_format.UnitCode}";
          System.Diagnostics.Debug.WriteLine(line);
        System.Diagnostics.Debug.WriteLine("");
    Get The List of Unit Formats for the Current Project
      // Note: Must be on the QueuedTask.Run()
      System.Diagnostics.Debug.WriteLine("Project units\r\n");
        var units = DisplayUnitFormats.Instance.GetProjectUnitFormats(unit_format);
    Get A Specific List of Unit Formats for the Current Project
      //Must be on the QueuedTask.Run()
      //UnitFormatType.Angular, UnitFormatType.Area, UnitFormatType.Distance,
      //UnitFormatType.Direction, UnitFormatType.Location, UnitFormatType.Page
      //UnitFormatType.Symbol2D, UnitFormatType.Symbol3D
      var units = DisplayUnitFormats.Instance.GetProjectUnitFormats(UnitFormatType.Distance);
      // Use units;
    Get The List of Default Formats for the Current Project
      System.Diagnostics.Debug.WriteLine("Default project units\r\n");
        var default_unit = DisplayUnitFormats.Instance.GetDefaultProjectUnitFormat(unit_format);
        var line = $"{unit_format}: {default_unit.DisplayName}, {default_unit.UnitCode}";
    Get A Specific Default Unit Format for the Current Project
      // Use default_unit;
    Set a Specific List of Unit Formats for the Current Project
      //Get the full list of all available location units
      var all_units = DisplayUnitFormats.Instance.GetPredefinedProjectUnitFormats(
                                                          UnitFormatType.Location);
      //keep units with an even factory code
      var list_units = all_units.Where(du => du.UnitCode % 2 == 0).ToList();
      //set them as the new location unit collection. A new default is not being specified...
      DisplayUnitFormats.Instance.SetProjectUnitFormats(list_units);
      //set them as the new location unit collection along with a new default
                                              list_units, list_units.First());
      //Note: UnitFormatType.Page, UnitFormatType.Symbol2D, UnitFormatType.Symbol3D
      //cannot be set.
    Set the Defaults for the Project Unit Formats
      var unit_formats = Enum.GetValues(typeof(UnitFormatType)).OfType<UnitFormatType>().ToList();
      foreach (var unit_type in unit_formats)
        var current_default = DisplayUnitFormats.Instance.GetDefaultProjectUnitFormat(unit_type);
        //Arbitrarily pick the last unit in each unit format list
        var replacement = DisplayUnitFormats.Instance.GetProjectUnitFormats(unit_type).Last();
        DisplayUnitFormats.Instance.SetDefaultProjectUnitFormat(replacement);
        var line = $"{current_default.DisplayName}, {current_default.UnitName}, {current_default.UnitCode}";
        var line2 = $"{replacement.DisplayName}, {replacement.UnitName}, {replacement.UnitCode}";
        System.Diagnostics.Debug.WriteLine($"Format: {unit_type}");
        System.Diagnostics.Debug.WriteLine($" Current default: {line}");
        System.Diagnostics.Debug.WriteLine($" Replacement default: {line2}");
    Update Unit Formats for the Project
      var angle_units = DisplayUnitFormats.Instance.GetProjectUnitFormats(UnitFormatType.Angular);
      //Edit the display name of each unit - append the abbreviation
      foreach (var unit in angle_units)
        unit.DisplayName = $"{unit.DisplayName} ({unit.Abbreviation})";
      //apply the changes to the units and set the default to be the first entry
      DisplayUnitFormats.Instance.SetProjectUnitFormats(angle_units, angle_units.First());
      //The project must be saved to persist the changes...
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Core.UnitFormats.UnitFormatType
    Requirements
