ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ClientToPage Method
The point in client coordinates
    ClientToPage Method (LayoutView)
    Converts a point in client coordinates to a point in page coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Coordinate2D ClientToPage(
       Point clientPoint
    Public Function ClientToPage( _
       ByVal clientPoint As Point _
    ) As Coordinate2D
    Parameters
    clientPoint
    Return Value
    The converted point in page coordinates
    Exceptions
    ExceptionDescription
    Remarks
    Client coordinates must be in pixels relative to the top-left corner of the view. If either client coordinate value is double.NaN then a coordinate with X, Y both set to System.Double.NaN is returned. Page coordinates will be in the current units of the page.
    Requirements
