ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ClientToScreen Method
The point value in client coordinates.
    ClientToScreen Method (LayoutView)
    Converts a point in screen coordinates to a point in client coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Point ClientToScreen(
       Point clientPoint
    Public Function ClientToScreen( _
       ByVal clientPoint As Point _
    ) As Point
    Parameters
    clientPoint
    Return Value
    The converted point in screen coordinates.
    Exceptions
    ExceptionDescription
    clientPoint
    Remarks
    Client coordinates must be in pixels relative to the top-left corner of the view. If either client coordinate value is double.NaN then a point with X, Y both set to System.Double.NaN is returned.
    Requirements
